Saltar al contenido principal
Shark NV352 Filter Replacement
  1. Shark NV352 Filter Replacement, Filter: paso 1, imagen 1 de 1
    • Ensure that you are removing the filters from the vacuum in an area that you don't mind getting dirty because the filters will be very dusty.
    • Lift the latches on both sides of the vacuum to release the dust canister.
  2. Shark NV352 Filter Replacement: paso 2, imagen 1 de 2 Shark NV352 Filter Replacement: paso 2, imagen 2 de 2
    • Tilt the dust canister forward to release it from its position.
    • Carefully lift away the dust canister and set it aside.
  3. Shark NV352 Filter Replacement: paso 3, imagen 1 de 3 Shark NV352 Filter Replacement: paso 3, imagen 2 de 3 Shark NV352 Filter Replacement: paso 3, imagen 3 de 3
    • Remove the upper filter by lifting upwards on it.
    • Now that the lower filter is exposed, remove it by pulling it upwards.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team S18-G5, Forte Fall 2017 Miembro de Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 20
Todo El Tiempo: 966
