Saltar al contenido principal
Shark Matrix RV2310 Wheel Assembly Replacement
Qué necesitas
  1. Shark Matrix RV2310 Wheel Assembly Replacement, Battery: paso 1, imagen 1 de 3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: paso 1, imagen 2 de 3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the two 11 mm Phillips screws holding the battery plate in place.
    • Remove the battery plate.
  2. Shark Matrix RV2310 Wheel Assembly Replacement: paso 2, imagen 1 de 3 Shark Matrix RV2310 Wheel Assembly Replacement: paso 2, imagen 2 de 3 Shark Matrix RV2310 Wheel Assembly Replacement: paso 2, imagen 3 de 3
    • Remove the battery from the compartment.
    • Disconnect the electrical cable connection from the battery to the robot.
  3. Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: paso 3, imagen 1 de 2 Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: paso 3, imagen 2 de 2
    • Remove the five 11 mm Phillips screws holding the wheel assembly in place.
    • Make sure the device's battery has been fully removed from the device before proceeding. Failure to do so could potentially result in minor/moderate injuries.
  4. Shark Matrix RV2310 Wheel Assembly Replacement: paso 4, imagen 1 de 1
    • Lift the wheel assembly out of the vacuum.
    • Do not pull or tug too hard on the wheel when lifting it, as there is a wire connection between the wheel and the motherboard.
  5. Shark Matrix RV2310 Wheel Assembly Replacement: paso 5, imagen 1 de 1
    • Undo the wire connection between the motherboard and the wheel assembly by gently pulling the wire out from the wheel assembly's connector.
Conclusión
Joshua Correia
Miembro Desde 03/22/24
607 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 39
