Saltar al contenido principal
Introducción
If the handle for your Steam Pocket Mop gets loose and falls off, or if you would like to remove the handle for easy storage, use this guide to walk you through the process. You will need a Phillips #2 screwdriver for this replacement.
Partes
No se especificaron partes.
  1. Turn off the Steam Pocket Mop and unplug it from the wall.
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that any water in the water tank cools before proceeding.
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. Place the Steam Pocket Mop face down on a flat surface.
    • Place the Steam Pocket Mop face down on a flat surface.
    • Take note of the placement of the handle; the side labelled "front" should should face forward.
  4. Remove the screw located underneath the cord holder. Turn the screwdriver counter-clockwise to loosen the screw from its slot. This is a long screw and will take time to remove.
    • Remove the screw located underneath the cord holder.
    • Turn the screwdriver counter-clockwise to loosen the screw from its slot.
    • This is a long screw and will take time to remove.
Conclusión
To disassemble your device, follow these instructions in reverse order.
Nancy K Do
Miembro Desde 17/10/18
147 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team S1-G3, Rose Fall 2018 Miembro de UW Tacoma, Team S1-G3, Rose Fall 2018
UWT-ROSE-F18S1G3
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 93
