Introducción
This guide will go over how to remove and replace the two main rear wheels on the Shark AV993. This repair might be needed in case your two main rear wheels are clogged with dust and debris. This guide is also helpful for when your wheels start to crack and break and need to be replaced with new ones.
Qué necesitas
Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
Flip over the vacuum so that the bottom is facing upwards.
Remove the five 14 mm screws using a T20 Torx screwdriver.
Una persona más ha completado esta guía.
