Saltar al contenido principal
Shark IQ AV993 Bumper Replacement
Qué necesitas
  1. Shark IQ AV993 Bumper Replacement, Battery: paso 1, imagen 1 de 1
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
  2. Shark IQ AV993 Bumper Replacement: paso 2, imagen 1 de 1
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
  3. Shark IQ AV993 Bumper Replacement, Bumper: paso 3, imagen 1 de 2 Shark IQ AV993 Bumper Replacement, Bumper: paso 3, imagen 2 de 2
    • Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
  4. Shark IQ AV993 Bumper Replacement: paso 4, imagen 1 de 1
    • Pry both ends of the black piece to snap it out of place.
  5. Shark IQ AV993 Bumper Replacement: paso 5, imagen 1 de 1
    • Use both hands to lift the device.
    • The front bumper that is seated on the device will fall off.
    • This is completely normal, as the screws and the bottom holder are the only things holding the bumper in place.
Conclusión
Kyle Rhines
Miembro Desde 10/26/22
558 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 3-3, Botvin Fall 2022 Miembro de UMass Dartmouth, Team 3-3, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G3
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 824
