Saltar al contenido principal
Shark IONFlex 2X Soft Brush Roll Replacement
  1. Shark IONFlex 2X Soft Brush Roll Replacement, Soft Brush Roll: paso 1, imagen 1 de 1
    • Press and slide the access brush roll buttons towards the "Access Brush Roll" printing on casing.
  2. Shark IONFlex 2X Soft Brush Roll Replacement: paso 2, imagen 1 de 1
    • Lift plastic casing upward and off of the top of the floor unit. Place off to the side.
  3. Shark IONFlex 2X Soft Brush Roll Replacement: paso 3, imagen 1 de 1
    • Pull the red Pull tab that is located on the right side of the soft brush roll away from the front of the vacuum and place the soft brush roll to the side.
Conclusión
2 personas más completaron esta guía.
Un comentario
I’m trying to fix the plastic gear that the roller fits onto. It’s broken and I think it needs to be disassembled more and need replacement parts. Model # IF200W. Any advice??
Anthony - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 2,601
