Saltar al contenido principal
Shark IONFlex 2X Motherboard Replacement
Qué necesitas
  1. Shark IONFlex 2X Motherboard Replacement, Brush Roll Band: paso 1, imagen 1 de 1
    • Press and slide the “access brush roll” buttons towards the text and lift plastic brush roll cover off.
  2. Shark IONFlex 2X Motherboard Replacement: paso 2, imagen 1 de 2 Shark IONFlex 2X Motherboard Replacement: paso 2, imagen 2 de 2
    • Gently pry the circular screw cover off of the side of the casing with the shoe print mark on it with the small metal spudger.
  3. Shark IONFlex 2X Motherboard Replacement: paso 3, imagen 1 de 1
    • Use a T20 screwdriver to unscrew the 12.3 mm screw beneath the cover you just removed.
  4. Shark IONFlex 2X Motherboard Replacement: paso 4, imagen 1 de 2 Shark IONFlex 2X Motherboard Replacement: paso 4, imagen 2 de 2
    • Move to the side of the casing with the shoe print mark. Use the T20 screwdriver to unscrew the 18mm screw.
  5. Shark IONFlex 2X Motherboard Replacement: paso 5, imagen 1 de 3 Shark IONFlex 2X Motherboard Replacement: paso 5, imagen 2 de 3 Shark IONFlex 2X Motherboard Replacement: paso 5, imagen 3 de 3
    • Use the small metal spudger to gently separate the side casing from the main body.
  6. Shark IONFlex 2X Motherboard Replacement: paso 6, imagen 1 de 1
    • Use the large plastic opening tool to pry the rubber brushroll band towards you until the rubber brush roll band comes off of the small metal gear.
  7. Shark IONFlex 2X Motherboard Replacement: paso 7, imagen 1 de 2 Shark IONFlex 2X Motherboard Replacement: paso 7, imagen 2 de 2
    • Pull the rubber brush roll band out of the large white gear.
  8. Shark IONFlex 2X Motherboard Replacement, Motherboard: paso 8, imagen 1 de 3 Shark IONFlex 2X Motherboard Replacement, Motherboard: paso 8, imagen 2 de 3 Shark IONFlex 2X Motherboard Replacement, Motherboard: paso 8, imagen 3 de 3
    • Unscrew the six 18.7mm screws in the bottom casing using a T20 screwdriver.
  9. Shark IONFlex 2X Motherboard Replacement: paso 9, imagen 1 de 2 Shark IONFlex 2X Motherboard Replacement: paso 9, imagen 2 de 2
    • Turn over the machine and lift the top casing off.
  10. Shark IONFlex 2X Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the large black plastic plug using your fingers and/or long nose pliers.
  11. Shark IONFlex 2X Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove large white plastic plug using your fingers and/or long nose pliers.
  12. Shark IONFlex 2X Motherboard Replacement: paso 12, imagen 1 de 1
    • Squeeze tabs and remove small white plug with two white wires coming out of it.
  13. Shark IONFlex 2X Motherboard Replacement: paso 13, imagen 1 de 1
    • Squeeze tabs and remove small white plug with white and black wires coming out of it.
  14. Shark IONFlex 2X Motherboard Replacement: paso 14, imagen 1 de 1
    • Squeeze the three plastic caps enclosing the crimped connection of the red, black and yellow wires extending outward from the motherboard to release the wires from the grip of the plastic caps.
    • You may have to adjust how you are squeezing the plastic caps to get the connection to release.
  15. Shark IONFlex 2X Motherboard Replacement: paso 15, imagen 1 de 3 Shark IONFlex 2X Motherboard Replacement: paso 15, imagen 2 de 3 Shark IONFlex 2X Motherboard Replacement: paso 15, imagen 3 de 3
    • Remove the caps from the red, black and yellow wires to expose the three metal clamps.
  16. Shark IONFlex 2X Motherboard Replacement: paso 16, imagen 1 de 2 Shark IONFlex 2X Motherboard Replacement: paso 16, imagen 2 de 2
    • Cut the red wires extending beneath the metal clamp, right below the metal clamp holding the two wires together. Repeat process for black and yellow wires.
  17. Shark IONFlex 2X Motherboard Replacement: paso 17, imagen 1 de 2 Shark IONFlex 2X Motherboard Replacement: paso 17, imagen 2 de 2
    • Unscrew the two 11.8mm screws in the motherboard using a T10 screwdriver.
  18. Shark IONFlex 2X Motherboard Replacement: paso 18, imagen 1 de 2 Shark IONFlex 2X Motherboard Replacement: paso 18, imagen 2 de 2
    • Remove the motherboard.
Conclusión
3 personas más completaron esta guía.
2 comentarios
Thanks for the guide. I had an issue where the lights would switch on but the roller would not spin. After taking it apart I found the issue. When putting the cover on the plastic tab that needs to engage the roller switch slides behind the ‘button’ for the switch.
hard to explain but if you take off the side where the motherboard is you will see the green micro switch follow the spring loaded button to the front of the unit. The plastic tab on the cover slides in besides it causing it not to engage the switch
wozsocial - Contestar
This guide is for removal of the brush roller motherboard, yet is labelled as the IONFlex 2X motherboard which happens to be a number of PCBs in the hand held part of this unit.
Mis-leading title.
infiniti25 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 2,357
