Introducción
Is your Shark ION Robot S87 throwing error messages or is there no suction anymore? The primary reason for these occurrences is a loose or faulty trash tray. This happens when the vacuum sucks large or pointed items. To fix this, change your trash tray or check if it is not secured. Here is an easy guide to fix it.
Qué necesitas
Flip the Shark ION Robot so that the underside is facing up.
Hold the button on the bottom of the vacuum, and slide the tray away from the device.
