Saltar al contenido principal
Shark ION Robot S87 Drive Wheel Replacement
Qué necesitas
  1. Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: paso 1, imagen 1 de 2 Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: paso 1, imagen 2 de 2
    • Make sure device is turned off before attempting this replacement.
    • Remove three 13mm screws using a T15 Torx screwdriver.
    • Remove one 15mm screw using a Phillips #1 screwdriver.
    • Remove one final 15mm Phillips #1 screw.
  2. Shark ION Robot S87 Drive Wheel Replacement: paso 2, imagen 1 de 1
    • Carefully lift the wheel assembly out of the housing, making sure not to damage its connecting wire.
  3. Shark ION Robot S87 Drive Wheel Replacement: paso 3, imagen 1 de 1
    • Disconnect the wire carefully from the wheel assembly by pinching and pulling away from it.
Conclusión
Una persona más ha completado esta guía.
Trevor Davies
Miembro Desde 01/14/20
297 Reputación
2 Guías creadas
Equipo
Un comentario
Dude you made my day. Cost me 14 bucks for a torx set and fixed my little cleaning buddy. All it needed was to be blown out with compressed air and plugged back in. THANK YOU!!!
DovieAndiSeTova - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 1,718
