Saltar al contenido principal
Shark ION Robot S87 Bumper Replacement
Qué necesitas
  1. Shark ION Robot S87 Bumper Replacement, Bumper: paso 1, imagen 1 de 1
    • Flip the Shark ION Robot S87 on its underside so that the bumper and its screws are facing upwards.
    • Use a Hex 2mm screwdriver to remove the five 8mm screws from the bumper.
  2. Shark ION Robot S87 Bumper Replacement: paso 2, imagen 1 de 3 Shark ION Robot S87 Bumper Replacement: paso 2, imagen 2 de 3 Shark ION Robot S87 Bumper Replacement: paso 2, imagen 3 de 3
    • Once all screws have been removed lift the thin side of the bumper upwards to remove it from the robot.
    • Lift the robot up so that the larger part of the bumper stays on the floor and is removed.
    • Once both pieces of the bumper have been removed, you can place the robot back down.
  3. Shark ION Robot S87 Bumper Replacement: paso 3, imagen 1 de 1
    • Check all sensors and remove any that may have debris in front of it.
    • You may also swap out the bumper for another depending on whether or not it is broken.
Conclusión
2 personas más completaron esta guía.
Adeel Ahmad
Miembro Desde 01/14/20
256 Reputación
2 Guías creadas
Equipo
Un comentario
Where can I buy a new bumper?
Lacy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 29
Ultimos 30 días: 136
Todo El Tiempo: 11,808
