Saltar al contenido principal
Shark ION Robot R75 Main Brush Replacement
  1. Shark ION Robot R75 Main Brush Replacement, Main Brush: paso 1, imagen 1 de 1
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
  2. Shark ION Robot R75 Main Brush Replacement: paso 2, imagen 1 de 1
    • Pull the main brush slightly to the right to remove it from the compartment.
  3. Shark ION Robot R75 Main Brush Replacement: paso 3, imagen 1 de 2 Shark ION Robot R75 Main Brush Replacement: paso 3, imagen 2 de 2
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
Conclusión
Un comentario
My shark ion stopped working after about 6 months and it started giving an error on the brush. I cleaned my vacuum pretty regularly, at least once a week. I ordered a replacement brush and it still hasn't fixed it. Do you have any other suggestions?
Tina Hicks - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 74
Todo El Tiempo: 2,610
