Saltar al contenido principal
Shark ION Robot R75 Caster Wheel Replacement
Qué necesitas
  1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: paso 1, imagen 1 de 1
    • Orient the device with the bottom facing up.
  2. Shark ION Robot R75 Caster Wheel Replacement: paso 2, imagen 1 de 3 Shark ION Robot R75 Caster Wheel Replacement: paso 2, imagen 2 de 3 Shark ION Robot R75 Caster Wheel Replacement: paso 2, imagen 3 de 3
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
  3. Shark ION Robot R75 Caster Wheel Replacement: paso 3, imagen 1 de 3 Shark ION Robot R75 Caster Wheel Replacement: paso 3, imagen 2 de 3 Shark ION Robot R75 Caster Wheel Replacement: paso 3, imagen 3 de 3
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
Conclusión
Un comentario
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 25
Ultimos 30 días: 113
Todo El Tiempo: 4,702
