Introducción
If you cannot charge your Shark ION Robot, there may be a problem with the charging dock motherboard, which requires a replacement.
Damage to the charging dock could cause damage to the battery when trying to charge it or even a heat reaction, which could cause fires or other malfunctions.
Qué necesitas
Remove the three Torx T6 screws on the underside of the charging dock.
Lift off the lower case.
Casi Terminas!
Conclusión
