Saltar al contenido principal
Shark ION Robot 750 Battery Replacement
Qué necesitas
  1. Shark ION Robot 750 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the device is completely powered off before working.
    • On the bottom of the vacuum, unscrew both sides of the vacuum cover using a Phillips screwdriver.
    • Gently lift and remove the cover.
  2. Shark ION Robot 750 Battery Replacement: paso 2, imagen 1 de 2 Shark ION Robot 750 Battery Replacement: paso 2, imagen 2 de 2
    • Grip both of the battery pull tabs and lift the battery out.
    • Be careful when lifting the battery out because it is still connected to the motherboard.
  3. Shark ION Robot 750 Battery Replacement: paso 3, imagen 1 de 2 Shark ION Robot 750 Battery Replacement: paso 3, imagen 2 de 2
    • To disconnect the battery, firmly squeeze down on the marked tabs, then pull the connector out of the socket.
Linea de Meta
1Guía Comentario
Does the new battery need charging once inserted and if so how long? Mine did nothing once inserted. It didn't even light up!
Donna Ray-Reifler - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 201
