Saltar al contenido principal
Shark ION Robot 750 Battery Replacement
Qué necesitas
  1. Shark ION Robot 750 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the device is completely powered off before working.
    • On the bottom of the vacuum, unscrew both sides of the vacuum cover using a Phillips screwdriver.
    • Gently lift and remove the cover.
  2. Shark ION Robot 750 Battery Replacement: paso 2, imagen 1 de 2 Shark ION Robot 750 Battery Replacement: paso 2, imagen 2 de 2
    • Grip both of the battery pull tabs and lift the battery out.
    • Be careful when lifting the battery out because it is still connected to the motherboard.
  3. Shark ION Robot 750 Battery Replacement: paso 3, imagen 1 de 2 Shark ION Robot 750 Battery Replacement: paso 3, imagen 2 de 2
    • To disconnect the battery, firmly squeeze down on the marked tabs, then pull the connector out of the socket.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 117
