Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If you need to replace the motor of your Shark Flex DuoClean, follow this guide. To remove the motor, soldering skills are required. See this guide for soldering instructions.
  1. Open the garage door by sliding both of the release buttons away from you. Lift off the garage door.
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out. Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw. Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Use the iFixit Opening Tool to pry the side of the vacuum open.
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Remove the side component with your hands.
    • Remove the side component with your hands.
  6. Remove the four 15 mm T10 screws on the underside of the vacuum.
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
  7. Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum. Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
  8. Orient the vacuum so you are looking down at the open garage of the vacuum. Using your right hand, rotate the top of the silver motor towards the brush roll of the vacuum so the motor fits through the opening.
    • Orient the vacuum so you are looking down at the open garage of the vacuum.
    • Using your right hand, rotate the top of the silver motor towards the brush roll of the vacuum so the motor fits through the opening.
  9. With both thumbs, push the gear on the right side of the motor into the vacuum. The motor should pop out.
    • With both thumbs, push the gear on the right side of the motor into the vacuum. The motor should pop out.
    • Slowly pull the motor out of the vacuum base and reveal the electrical cords.
  10. To fully remove the motor, cut the wires.
    • To fully remove the motor, cut the wires.
    • For reassembly, use the soldering guide in the Introduction.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team S17-G5, White Fall 2018 Miembro de Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Miembros
11 Guías creadas
Can this motor we test it before taking it out
craigfranz - Contestar
Can this motor be tested before taking it out?
Will you be able to take out the brush roll in front of the motor?
CAM BAP - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 18
Ultimos 7 días: 91
Ultimos 30 días: 362
Todo El Tiempo: 5,961
