Saltar al contenido principal
Shark Flex DuoClean LED Headlight Replacement
Qué necesitas
  1. Shark Flex DuoClean LED Headlight Replacement, Garage Door: paso 1, imagen 1 de 2 Shark Flex DuoClean LED Headlight Replacement, Garage Door: paso 1, imagen 2 de 2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean LED Headlight Replacement, Side Component: paso 2, imagen 1 de 2 Shark Flex DuoClean LED Headlight Replacement, Side Component: paso 2, imagen 2 de 2
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean LED Headlight Replacement: paso 3, imagen 1 de 2 Shark Flex DuoClean LED Headlight Replacement: paso 3, imagen 2 de 2
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean LED Headlight Replacement: paso 4, imagen 1 de 1
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean LED Headlight Replacement: paso 5, imagen 1 de 1
    • Remove the side component with your hands.
  6. Shark Flex DuoClean LED Headlight Replacement, LED Headlight: paso 6, imagen 1 de 1
  7. Shark Flex DuoClean LED Headlight Replacement: paso 7, imagen 1 de 2 Shark Flex DuoClean LED Headlight Replacement: paso 7, imagen 2 de 2
    • Use the nylon spudger to pry the gold, plastic cover off of the headlights.
    • Prying off the cover too aggressively may cause it to break.
  8. Shark Flex DuoClean LED Headlight Replacement: paso 8, imagen 1 de 2 Shark Flex DuoClean LED Headlight Replacement: paso 8, imagen 2 de 2
  9. Shark Flex DuoClean LED Headlight Replacement: paso 9, imagen 1 de 2 Shark Flex DuoClean LED Headlight Replacement: paso 9, imagen 2 de 2
    • Use the metal spudger to pry off the clear, plastic cover on the LEDs.
    • Prying the cover off too aggressively may cause it to break.
  10. Shark Flex DuoClean LED Headlight Replacement: paso 10, imagen 1 de 1
    • Use wire cutters to detach the black cables from the LEDs on both sides.
    • Strip 1 cm off the ends of the wires, using a wire stripper.
    • Solder the exposed wires to the new LEDs.
    • Use the soldering guide in the Introduction.
Conclusión
Equipo
Cal Poly, Team S17-G5, White Fall 2018 Miembro de Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,362
