Saltar al contenido principal
Shark Flex DuoClean Brush Roll Replacement
  1. Shark Flex DuoClean Brush Roll Replacement, Garage Door: paso 1, imagen 1 de 2 Shark Flex DuoClean Brush Roll Replacement, Garage Door: paso 1, imagen 2 de 2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Brush Roll Replacement, Soft Roller: paso 2, imagen 1 de 2 Shark Flex DuoClean Brush Roll Replacement, Soft Roller: paso 2, imagen 2 de 2
    • Use the tab on the right side to lift out the soft roller.
Conclusión
2 personas más completaron esta guía.
caoimhe
Miembro Desde 10/08/18
979 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S17-G5, White Fall 2018 Miembro de Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Miembros
14 Guías creadas
23 comentarios
There’s nothing blocking the soft roller in mine. I can spin it by hand. Only the regular brush roll spins. Now what?
Keith Sauer - Contestar
I have the same problem. The gear that is connected to the motor that spins the soft brush roller is stripped. The shaft spins but the inside of the gear is stripped therefore it doesnt turn the soft brush roller. I cannot find the replacement part
Bill Pucher - Contestar
Having this same problem
Keona Taylor -
Same here…no blockage, but won’t spin
tbridge - Contestar
I also have the same problem. No blockage. The brush roller works but the soft roller does not spin.
Gina - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 22
Ultimos 30 días: 70
Todo El Tiempo: 10,373
