Saltar al contenido principal
Shark Cordless Pet Perfect Front Motor Replacement
Qué necesitas
  1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: paso 1, imagen 1 de 2 Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: paso 1, imagen 2 de 2
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Motor  Replacement: paso 2, imagen 1 de 3 Shark Cordless Pet Perfect Front Motor  Replacement: paso 2, imagen 2 de 3 Shark Cordless Pet Perfect Front Motor  Replacement: paso 2, imagen 3 de 3
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Motor  Replacement: paso 3, imagen 1 de 3 Shark Cordless Pet Perfect Front Motor  Replacement: paso 3, imagen 2 de 3 Shark Cordless Pet Perfect Front Motor  Replacement: paso 3, imagen 3 de 3
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Motor  Replacement: paso 4, imagen 1 de 2 Shark Cordless Pet Perfect Front Motor  Replacement: paso 4, imagen 2 de 2
    • Remove the belt from the motor mount, and then replace with a new belt.
  5. Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: paso 5, imagen 1 de 2 Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: paso 5, imagen 2 de 2
    • Remove the solder from both motor terminals.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 16-2, Blackwell Spring 2017 Miembro de USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Miembros
11 Guías creadas
2 comentarios
Well done, Ashley! You might want to note that using a solder remover is helpful.
Jimbo - Contestar
Where can I obtain the new motor with the plastic gear?
F V - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 2,659
