Saltar al contenido principal
Shark Cordless Pet Perfect Front Belt Replacement
Qué necesitas
  1. Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: paso 1, imagen 1 de 2 Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: paso 1, imagen 2 de 2
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Belt Replacement: paso 2, imagen 1 de 3 Shark Cordless Pet Perfect Front Belt Replacement: paso 2, imagen 2 de 3 Shark Cordless Pet Perfect Front Belt Replacement: paso 2, imagen 3 de 3
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Belt Replacement: paso 3, imagen 1 de 3 Shark Cordless Pet Perfect Front Belt Replacement: paso 3, imagen 2 de 3 Shark Cordless Pet Perfect Front Belt Replacement: paso 3, imagen 3 de 3
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Belt Replacement: paso 4, imagen 1 de 2 Shark Cordless Pet Perfect Front Belt Replacement: paso 4, imagen 2 de 2
    • Remove the belt from the motor mount, and then replace with a new belt.
Conclusión
Ben Dzugen
Miembro Desde 02/02/17
383 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 16-2, Blackwell Spring 2017 Miembro de USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Miembros
11 Guías creadas
2 comentarios
Nice and simple but where can we purchase the belts?
jmrlachance - Contestar
My shark pet vacuum didn't come with lint brush roller. How do I get one. I buy these pet vacuum for friends/family. Please respond
Tina Cherney - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 2,665
