Saltar al contenido principal
Shark Cordless Pet Perfect Battery Replacement
Qué necesitas
  1. Shark Cordless Pet Perfect Battery Replacement, Battery: paso 1, imagen 1 de 3 Shark Cordless Pet Perfect Battery Replacement, Battery: paso 1, imagen 2 de 3 Shark Cordless Pet Perfect Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the Dust Cap Container then remove the 7.5mm screw (with the PH2 Bit) from the battery cover.
    • Using a black spudger pry open the cover, and remove the cover plate.
  2. Shark Cordless Pet Perfect Battery Replacement: paso 2, imagen 1 de 2 Shark Cordless Pet Perfect Battery Replacement: paso 2, imagen 2 de 2
    • Once the battery cover is removed slide the battery mount upwards and pull it out.
  3. Shark Cordless Pet Perfect Battery Replacement: paso 3, imagen 1 de 3 Shark Cordless Pet Perfect Battery Replacement: paso 3, imagen 2 de 3 Shark Cordless Pet Perfect Battery Replacement: paso 3, imagen 3 de 3
    • Pull out the battery and then disconnect the battery at the quick disconnects.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 16-2, Blackwell Spring 2017 Miembro de USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Miembros
11 Guías creadas
4 comentarios
Throw it away and buy new lithium Pet Perfect
John Carson - Contestar
I changed the battery, it still shuts off after 1 second
Garry - Contestar
It has a 2 year warranty, mine quit working at 2 years 10 months. Pretty expensive for only 34 months.
Ralph E Beaver - Contestar
Mine still working after 3 (three)years and it was $45 at the time from Walmart. Wouldn't be cheaper to buy an other whole unit than waste $45 plus tax, plus work just on the battery pack like Amazon's Banshee ( read EXTRATERRESTRIAL ) battery pack of $45 plus tax ???
Aurel Tita - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 26
Ultimos 30 días: 98
Todo El Tiempo: 13,751
