Introducción
This guide will show you how to take apart the fan to remove the Printed Circuit Board.
Partes
No se requieren partes.
  1. Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
    • Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
    • Do this by unscrewing from left-to-right then pull the screws out of the back of the fan
  2. Pull the front and back cover apart.
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely because it holds the wires.
    • Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
    • Make sure the fan is unplugged while removing the circuit board as you may get shocked.
    • To remove the screws, unscrew in a left-to-right fashion at an angle to make sure that the wires do not get tangled.
    • Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
    • Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you may damage circuit elements.
    • Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
Conclusión
Mateo Begue
Miembro Desde 26/09/12
87 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-46, Forte Fall 2012 Miembro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 894
