Saltar al contenido principal
SereneLife Treadmill SLFTRD20 Belt Adjustment
Qué necesitas
  1. SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 1, imagen 1 de 2 SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 1, imagen 2 de 2
    • Turn on the main power switch.
  2. SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 2, imagen 1 de 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 2, imagen 2 de 2
    • Begin by pressing the "Start" button on the machine.
    • Let the treadmill belt run at the lowest setting.
  3. SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 3, imagen 1 de 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 3, imagen 2 de 2
    • In order to locate the roller adjustment bolts, try locating the rear left cover and rear right cover.
  4. SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 4, imagen 1 de 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 4, imagen 2 de 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 4, imagen 3 de 3
    • Remove the attached rear left and right covers from the treadmill.
    • After removing the rear covers, you'll be able to see the adjustment bolts.
  5. SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 5, imagen 1 de 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 5, imagen 2 de 2
    • Before we begin it's important to determine which side the belt is shifting towards.
    • If the belt is shifting to the right, then turn the right adjustment bolt to turn 1/4 clockwise. If the belt is shifting to the left, then turn the left adjustment bolt to turn 1/4 clockwise.
    • Place the Allen wrench in the left rear roller bolt.
    • Turn the left roller bolt adjustment to turn one-fourth clockwise.
    • Now stop and wait for the belt to begin to center itself.
    • You must wait for the belt to re-center between each adjustment to ensure that you do not overcorrect the belt.
  6. SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 6, imagen 1 de 1
    • In order to fix the slipping belt during use, we need to turn off and unplug the Treadmill.
  7. SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 7, imagen 1 de 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 7, imagen 2 de 3 SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 7, imagen 3 de 3
    • Place the Allen wrench in the left roller bolt and turn it 1/4 clockwise to tighten the belt.
    • Repeat on the right side of the roller bolt in the same way.
  8. SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 8, imagen 1 de 2 SereneLife Treadmill SLFTRD20 Belt Adjustment: paso 8, imagen 2 de 2
    • Attach the rear covers onto the left side and right side of the frames.
    • Turn the main power switch back on and run the treadmill at the lowest speed.
    • Run on the treadmill to determine if the belt is still slipping or not.
    • Repeat this procedure until the belt no longer slips.
Conclusión
2 personas más completaron esta guía.
Alina Abbas
Miembro Desde 07/03/21
211 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 12
Ultimos 30 días: 34
Todo El Tiempo: 1,769
