Saltar al contenido principal
Sennheiser RS120 Battery Replacement
Qué necesitas
  1. Sennheiser RS120 Battery Replacement, Ear Pad: paso 1, imagen 1 de 3 Sennheiser RS120 Battery Replacement, Ear Pad: paso 1, imagen 2 de 3 Sennheiser RS120 Battery Replacement, Ear Pad: paso 1, imagen 3 de 3
    • Grip the ear pad with one hand and steady the headset on the other.
    • Twist the ear pad counterclockwise, then lift the ear pad off after about an eighth of an inch of the turn.
    • Replace the old ear pad with a new ear pad.
  2. Sennheiser RS120 Battery Replacement, Battery: paso 2, imagen 1 de 2 Sennheiser RS120 Battery Replacement, Battery: paso 2, imagen 2 de 2
    • Twist the left ear pad counterclockwise to reveal the battery compartment within the headphone.
    • To remove batteries, push inward and lift up.
    • The battery should be able to pop out.
Conclusión
15 personas más completaron esta guía.
Gayle Dunham
Miembro Desde 03/03/10
375 Reputación
1 Guía escrita
7 comentarios
Thanks for the information - this made changing the batteries a snap.
Jim K - Contestar
Extremely helpful. Thank you!
-Randy N
Randy - Contestar
I own three sets and one quit working. As it turns out that the rechargeable batteries in that one set need replacing.
Until I purchase some rechargeable batteries, I am using standard AAA batteries and just have to remember NOT to put the headset back on the cradle.
Thanks for the info on how to access the batteries !
mcgilljp - Contestar
Thanks! You solved my mystery.
Marilyn Carini - Contestar
Good information, I wouldn’t have had a clue without it. Many thanks
Geoff Smith - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 29
Ultimos 30 días: 127
Todo El Tiempo: 44,936
