Introducción
If your Sega Saturn fails to read discs properly, use this guide to replace the disc reader.
The disc reader transmits data from a disc to the Saturn itself. A misaligned or damaged disc reader will stop the disc from spinning or cause the Saturn to display a “Drive Empty” message.
Before using this guide, clean the disk reader lens with a cotton ball and rubbing alcohol, as a dirty optical drive may be the cause of a disc reading failure.
Qué necesitas
Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
Una persona más ha completado esta guía.
