Saltar al contenido principal
Sega Master System Model 2 Disassembly
Qué necesitas
Resumen del Video
  1. Sega Master System Model 2 Disassembly, The Case: paso 1, imagen 1 de 1
    • Take out the 5 screws at the bottom
  2. Sega Master System Model 2 Disassembly, RF Shield: paso 2, imagen 1 de 1
    • Remove the 5 screws (3 at the back and 2 on the front)
    • Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
    • This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
  3. Sega Master System Model 2 Disassembly, Cartridge Slot: paso 3, imagen 1 de 1
    • Remove the 2 screws thats holding the cartridge slot down
  4. Sega Master System Model 2 Disassembly, The End: paso 4, imagen 1 de 1
    • Congratulations! You have opened your Sega Master System Model 2!
Conclusión
Screenshots taken from a video by Global Garage
3 personas más completaron esta guía.
Krisow
Miembro Desde 10/18/17
605 Reputación
2 Guías creadas
3 comentarios
This is in the wrong section.
Owen Ready - Contestar
Nope, its in the Sega Master System area.
Krisow -
Not a Master System
Chad Luciano - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 39
Todo El Tiempo: 2,336
