Introducción
This repair guide wil give a walk through on how to replace the power LED in a Sega Genesis.
Herramientas
Partes
No se especificaron partes.
Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
5 personas más completaron esta guía.
4 comentarios
My LED won't turn on when I turn on the machine though when I took it out and touched it on a battery it lit up. Did I put it back in wrong or what?
Long leg on the LED goes to the red wire.
Short leg to the white wire. If that's not the case, you may have burned the LED or the spot doesn't work anymore.
Last attempt would be getting your +V5 from the resistor below as shown in this image.
http://i.imgur.com/TucGEXj.jpg
Thunder....16
The model I am trying to change the led on is the 1601 HD graphics Genesis. The problem I have is there are NO simple easy press tabs to pop off the red ring. What is the correct way to remove the LED on this model? Thank you for your time.
Hey snoopy don't give up hope I made a video on how to fix your problem check out this video
