Saltar al contenido principal
Sega Game Gear Motherboard Replacement
Qué necesitas
  1. Sega Game Gear Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Motherboard Replacement: paso 2, imagen 1 de 1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Motherboard Replacement, Case: paso 3, imagen 1 de 1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Motherboard Replacement: paso 4, imagen 1 de 1
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Motherboard Replacement: paso 5, imagen 1 de 2 Sega Game Gear Motherboard Replacement: paso 5, imagen 2 de 2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Motherboard Replacement: paso 6, imagen 1 de 3 Sega Game Gear Motherboard Replacement: paso 6, imagen 2 de 3 Sega Game Gear Motherboard Replacement: paso 6, imagen 3 de 3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Motherboard Replacement, Motherboard: paso 7, imagen 1 de 1
    • Unscrew all the marked screws.
  8. Sega Game Gear Motherboard Replacement: paso 8, imagen 1 de 1
    • Slide the logic board out from under the circular black fastener at the top-left corner of the case.
  9. Sega Game Gear Motherboard Replacement: paso 9, imagen 1 de 1
    • Place the logic board on a flat surface.
Conclusión
8 personas más completaron esta guía.
Brandon Page
Miembro Desde 04/15/10
182 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 28-33, Regan Spring 2010 Miembro de Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 29
Ultimos 30 días: 161
Todo El Tiempo: 23,376
