Saltar al contenido principal
Sega Dreamcast Top Cover Replacement
Qué necesitas
  1. Sega Dreamcast Top Cover Replacement, Expansion Bay: paso 1, imagen 1 de 2 Sega Dreamcast Top Cover Replacement, Expansion Bay: paso 1, imagen 2 de 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Top Cover Replacement: paso 2, imagen 1 de 3 Sega Dreamcast Top Cover Replacement: paso 2, imagen 2 de 3 Sega Dreamcast Top Cover Replacement: paso 2, imagen 3 de 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Top Cover Replacement, Top Cover: paso 3, imagen 1 de 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Top Cover Replacement: paso 4, imagen 1 de 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
Conclusión
6 personas más completaron esta guía.
wkwong
Miembro Desde 11/14/09
533 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-1, Regan Fall 2009 Miembro de Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Miembros
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 19
Ultimos 30 días: 58
Todo El Tiempo: 12,019
