Introducción
Instructions on how to replace a defective Sega Dreamcast power supply with a working power supply.
Herramientas
Partes
No se requieren partes.
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Remove the white female pin head by pinching and lifting directly up on the harness.
Remove the two Philips #02 screws from the board.
Remove the power board. Using both hands, gently lift the power board away from the console without damaging the male pin head
5 personas más completaron esta guía.
