Introducción
A guide to remove the GD-ROM from the Sega Dreamcast.
Problem with this guide: The photos incorrectly show the power supply has been removed.
Partes
No se requieren partes.
Verify that the console is disconnected from the AC outlet before you begin.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Agregar Comentario
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Agregar Comentario
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
Agregar Comentario
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
Agregar Comentario
  • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
Agregar Comentario
  • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
Agregar Comentario
  • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
  • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
Agregar Comentario
  • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
  • Remove the GD-ROM by gently lifting it from its base.
Agregar Comentario
Conclusión
7 personas más completaron esta guía.
wkwong
Miembro Desde 14/11/09
414 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 5-1, Regan Fall 2009 Miembro de Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Miembros
23 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 18
Últimos 30 Días: 68
Todo El Tiempo: 14,836
