Saltar al contenido principal
Introducción
Use this guide to remove the power supply unit.
Partes
No se especificaron partes.
  1. Place the monitor face down.
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Remove two 11.5mm screws with a  #2 Phillips screwdriver.
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Using a  #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Pry the monitor using the plastic opening tool to release the clips holding the cover on. There are four clips on each side, four on the top, and one on the bottom. You may hear a loud snapping noise when releasing the clips.  Do not be alarmed, it is natural.
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  6. Using the  #2 Phillips screwdriver, remove the one 6mm screw. Unplug the indicated cable by pulling on the base.
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  7. Using a #2 Phillips screwdriver, remove the two 4.72 mm Phillips screws that hold the power adapter in place.
    • Using a #2 Phillips screwdriver, remove the two 4.72 mm Phillips screws that hold the power adapter in place.
  8. Unplug the seven connections from the power supply unit by gently pulling on them. Unplug the seven connections from the power supply unit by gently pulling on them. Unplug the seven connections from the power supply unit by gently pulling on them.
    • Unplug the seven connections from the power supply unit by gently pulling on them.
  9. Using a #2 Phillips screwdriver, remove the screws and the wire that is attached to the ground.
    • Using a #2 Phillips screwdriver, remove the screws and the wire that is attached to the ground.
    • Four 6 mm Phillips screws
    • One 8 mm Phillips screw
  10. Lift the power supply unit straight up to remove it from the back panel. Lift the power supply unit straight up to remove it from the back panel.
    • Lift the power supply unit straight up to remove it from the back panel.
Conclusión
Equipo
Cal Poly, Team 16-56, Forte Fall 2012 Miembro de Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 529
