Saltar al contenido principal
Sanyo-PM 8200 Motherboard Replacement
Qué necesitas
  1. Sanyo-PM 8200 Motherboard Replacement, Power Off Phone: paso 1, imagen 1 de 1
    • Power down the phone by holding down the red "end" button.
  2. Sanyo-PM 8200 Motherboard Replacement, Remove Old Battery: paso 2, imagen 1 de 1
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  3. Sanyo-PM 8200 Motherboard Replacement, Back Casing: paso 3, imagen 1 de 1
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
  4. Sanyo-PM 8200 Motherboard Replacement: paso 4, imagen 1 de 1
    • Unscrew all four, 5mm Tri-Wing screws.
  5. Sanyo-PM 8200 Motherboard Replacement: paso 5, imagen 1 de 2 Sanyo-PM 8200 Motherboard Replacement: paso 5, imagen 2 de 2
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
  6. Sanyo-PM 8200 Motherboard Replacement, Lift the Motherboard: paso 6, imagen 1 de 1
    • Gently lift up the motherboard. The keypad should now be exposed.
  7. Sanyo-PM 8200 Motherboard Replacement, Disconnect the Flex Ribbon: paso 7, imagen 1 de 1
    • Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
  8. Sanyo-PM 8200 Motherboard Replacement, Remove the Motherboard: paso 8, imagen 1 de 1
    • Remove the motherboard from the back of the phone.
Conclusión
Michaella
Miembro Desde 10/07/14
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-6, Leahy Fall 2014 Miembro de USF Tampa, Team 1-6, Leahy Fall 2014
USFT-LEAHY-F14S1G6
6 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 359
