Saltar al contenido principal
Sanyo VPC-X1200 Button Plate Replacement
Qué necesitas
  1. Sanyo VPC-X1200 Button Plate Replacement, Back Case: paso 1, imagen 1 de 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: paso 1, imagen 2 de 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: paso 1, imagen 3 de 3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 Button Plate Replacement: paso 2, imagen 1 de 1
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: paso 3, imagen 1 de 2 Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: paso 3, imagen 2 de 2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 Button Plate Replacement: paso 4, imagen 1 de 2 Sanyo VPC-X1200 Button Plate Replacement: paso 4, imagen 2 de 2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Sanyo VPC-X1200 Button Plate Replacement, Button Plate: paso 5, imagen 1 de 2 Sanyo VPC-X1200 Button Plate Replacement, Button Plate: paso 5, imagen 2 de 2
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Sanyo VPC-X1200 Button Plate Replacement: paso 6, imagen 1 de 2 Sanyo VPC-X1200 Button Plate Replacement: paso 6, imagen 2 de 2
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
Conclusión
Equipo
Cal Poly, Team 7-10, Maness Spring 2010 Miembro de Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,208
