Saltar al contenido principal
Sanyo VPC-T850 Shutter Button Replacement
Qué necesitas
  1. Sanyo VPC-T850 Shutter Button Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Shutter Button Replacement: paso 2, imagen 1 de 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Shutter Button Replacement: paso 3, imagen 1 de 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Shutter Button Replacement: paso 4, imagen 1 de 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: paso 5, imagen 1 de 3 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: paso 5, imagen 2 de 3 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: paso 5, imagen 3 de 3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 Shutter Button Replacement: paso 6, imagen 1 de 2 Sanyo VPC-T850 Shutter Button Replacement: paso 6, imagen 2 de 2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 Shutter Button Replacement: paso 7, imagen 1 de 1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 Shutter Button Replacement: paso 8, imagen 1 de 2 Sanyo VPC-T850 Shutter Button Replacement: paso 8, imagen 2 de 2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 Shutter Button Replacement: paso 9, imagen 1 de 1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
  10. Sanyo VPC-T850 Shutter Button Replacement, Shutter Button: paso 10, imagen 1 de 1
    • Find the chrome framing located on the top of the camera.
    • The physical shutter button apparatus is directly attached to this frame.
  11. Sanyo VPC-T850 Shutter Button Replacement: paso 11, imagen 1 de 2 Sanyo VPC-T850 Shutter Button Replacement: paso 11, imagen 2 de 2
    • Remove the three black screws connecting the chrome frame to the camera.
    • Three screws are located toward the front, with the remaining one above the display.
  12. Sanyo VPC-T850 Shutter Button Replacement: paso 12, imagen 1 de 1
    • Gently remove the loosened chrome frame and connected shutter button from the camera.
Conclusión
James Robinson
Miembro Desde 10/27/15
459 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 164
