Introducción
Steps on how to remove the lens. Removal of the LCD display and the outside case is required.
Herramientas
Partes
No se especificaron partes.
Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
Slide out and open the hatch located on the bottom-right side of the camera.
In the revealed compartment, move the small notch and push in on the battery to remove it.
Using the Phillips #00 Screwdriver, remove the 8 screws located around the sides and bottom of the camera.
Using the spudger, slowly pry the rear panel away from the left side.
The yellow ribbon is attached to the right side of the screen and goes to a black connector piece.
Gently flip the black connector away from the LCD screen to unlock the yellow ribbon.
Carefully pull the yellow ribbon towards the LCD screen to disconnect it.
The LCD screen should now be disconnected from the rest of the camera and a pry tool can be used to lift it out of its casing.
Una persona más ha completado esta guía.
