Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sanyo VPC-T850 LCD Display Replacement
Qué necesitas
  1. Sanyo VPC-T850 LCD Display Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
    Pregunta a FixBot
    Agregar Comentario
  2. Sanyo VPC-T850 LCD Display Replacement: paso 2, imagen 1 de 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
    Pregunta a FixBot
    Agregar Comentario
  3. Sanyo VPC-T850 LCD Display Replacement: paso 3, imagen 1 de 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
    Pregunta a FixBot
    Agregar Comentario
  4. Sanyo VPC-T850 LCD Display Replacement: paso 4, imagen 1 de 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
    Pregunta a FixBot
    Agregar Comentario
  5. Sanyo VPC-T850 LCD Display Replacement, Outer Casing: paso 5, imagen 1 de 3 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: paso 5, imagen 2 de 3 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: paso 5, imagen 3 de 3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
    Pregunta a FixBot
    Agregar Comentario
  6. Sanyo VPC-T850 LCD Display Replacement: paso 6, imagen 1 de 2 Sanyo VPC-T850 LCD Display Replacement: paso 6, imagen 2 de 2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
    Pregunta a FixBot
    Agregar Comentario
  7. Sanyo VPC-T850 LCD Display Replacement: paso 7, imagen 1 de 1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
    Pregunta a FixBot
    Agregar Comentario
  8. Sanyo VPC-T850 LCD Display Replacement: paso 8, imagen 1 de 2 Sanyo VPC-T850 LCD Display Replacement: paso 8, imagen 2 de 2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
    Pregunta a FixBot
    Agregar Comentario
  9. Sanyo VPC-T850 LCD Display Replacement: paso 9, imagen 1 de 1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
    Pregunta a FixBot
    Agregar Comentario
  10. Sanyo VPC-T850 LCD Display Replacement, LCD Display: paso 10, imagen 1 de 1
    • Flip the device over to where the display is located.
    • Using your plastic opening tool, lift the display out of its metal housing.
    Pregunta a FixBot
    Agregar Comentario
  11. Sanyo VPC-T850 LCD Display Replacement: paso 11, imagen 1 de 1
    • Locate the orange ribbon connecting the display to the camera.
    • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
    Pregunta a FixBot
    Agregar Comentario
  12. Sanyo VPC-T850 LCD Display Replacement: paso 12, imagen 1 de 1
    • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
    • Pull slowly to avoid severing the orange ribbon from the display.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Devin Farnsworth
Miembro Desde 10/29/15
101 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 49
Todo El Tiempo: 745
