Saltar al contenido principal
Sanyo VPC-T850 Battery Replacement
Qué necesitas
  1. Sanyo VPC-T850 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Battery Replacement: paso 2, imagen 1 de 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Battery Replacement: paso 3, imagen 1 de 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Battery Replacement: paso 4, imagen 1 de 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
Conclusión
Una persona más ha completado esta guía.
James Robinson
Miembro Desde 10/27/15
459 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 867
