Saltar al contenido principal
Sanyo VPC-S1415 LCD Replacement
Qué necesitas
  1. Sanyo VPC-S1415 LCD Replacement, LCD: paso 1, imagen 1 de 3 Sanyo VPC-S1415 LCD Replacement, LCD: paso 1, imagen 2 de 3 Sanyo VPC-S1415 LCD Replacement, LCD: paso 1, imagen 3 de 3
    • Here is a recently acquired camera. Initial cost $3.00
    • Only trouble is, obviously broken LCD
    • Remove the carrying strip. Use a needle and some tweezers to loosen the slip knot.
  2. Sanyo VPC-S1415 LCD Replacement: paso 2, imagen 1 de 3 Sanyo VPC-S1415 LCD Replacement: paso 2, imagen 2 de 3 Sanyo VPC-S1415 LCD Replacement: paso 2, imagen 3 de 3
    • Remove one screw on the right of the camera
    • Remove one screw on the left side of the camera
    • Remove the two screws on the bottom
  3. Sanyo VPC-S1415 LCD Replacement: paso 3, imagen 1 de 3 Sanyo VPC-S1415 LCD Replacement: paso 3, imagen 2 de 3 Sanyo VPC-S1415 LCD Replacement: paso 3, imagen 3 de 3
    • Split the camera from the battery compartment down. You can use an opening tools, or just your fingernails, if so equipped.
    • This will remove the front part of the case.
    • Remove this screw on the right side of the camera. Keep it separate from the 4 screws previously removed. The are of different length
  4. Sanyo VPC-S1415 LCD Replacement: paso 4, imagen 1 de 3 Sanyo VPC-S1415 LCD Replacement: paso 4, imagen 2 de 3 Sanyo VPC-S1415 LCD Replacement: paso 4, imagen 3 de 3
    • Remove the screw on the bottom of the battery compartment. Keep this screw with the one removed on the previous step. These two screws have a different length than all the other screws. They are the shortest ones in the camera
    • With those two screws removed, you can not separate the back part of the case.
    • Flip the LCD to the right and out of the frame. Do NOT try to remove it yet.
    • Remove the screw screws that hold the LCD frame to the logic board. Keep the 3 screws separated from the rest of the screws, due to different length.
  5. Sanyo VPC-S1415 LCD Replacement: paso 5, imagen 1 de 3 Sanyo VPC-S1415 LCD Replacement: paso 5, imagen 2 de 3 Sanyo VPC-S1415 LCD Replacement: paso 5, imagen 3 de 3
    • With the frame removed, the connector and LCD cable are now fully accessible. Note the to tabs on the cable and their position on the logic board.
    • Flip the tab on the connector carefully up and remove the LCD.
    • Hopefully this is what you will get after replacing the LCD and reassembling the camera in reverse order. Total replacement cost was $15 and 30 minutes of my time.
Conclusión
oldturkey03
Miembro Desde 09/29/10
782,145 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
537 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,958
