Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sanyo VPC S1275 Case Replacement
Qué necesitas
  1. Sanyo VPC S1275 Case Replacement, Battery: paso 1, imagen 1 de 1
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
    Pregunta a FixBot
  2. Sanyo VPC S1275 Case Replacement: paso 2, imagen 1 de 1
    • Remove and recycle old batteries.
    Pregunta a FixBot
  3. Sanyo VPC S1275 Case Replacement, Case: paso 3, imagen 1 de 3 Sanyo VPC S1275 Case Replacement, Case: paso 3, imagen 2 de 3 Sanyo VPC S1275 Case Replacement, Case: paso 3, imagen 3 de 3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
    Pregunta a FixBot
  4. Sanyo VPC S1275 Case Replacement: paso 4, imagen 1 de 2 Sanyo VPC S1275 Case Replacement: paso 4, imagen 2 de 2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
    Pregunta a FixBot
  5. Sanyo VPC S1275 Case Replacement: paso 5, imagen 1 de 3 Sanyo VPC S1275 Case Replacement: paso 5, imagen 2 de 3 Sanyo VPC S1275 Case Replacement: paso 5, imagen 3 de 3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
    Pregunta a FixBot
  6. Sanyo VPC S1275 Case Replacement: paso 6, imagen 1 de 1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
    Pregunta a FixBot
  7. Sanyo VPC S1275 Case Replacement: paso 7, imagen 1 de 1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
    Pregunta a FixBot
Conclusión
Equipo
Cal Poly, Team 24-24, Regan Spring 2010 Miembro de Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
Miembros de 4
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 76
Todo El Tiempo: 2,427
