Saltar al contenido principal
Sanyo SCP-8100 Speaker Replacement
Qué necesitas
  1. Sanyo SCP-8100 Speaker Replacement, Battery: paso 1, imagen 1 de 3 Sanyo SCP-8100 Speaker Replacement, Battery: paso 1, imagen 2 de 3 Sanyo SCP-8100 Speaker Replacement, Battery: paso 1, imagen 3 de 3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Sanyo SCP-8100 Speaker Replacement, Back Panel: paso 2, imagen 1 de 2 Sanyo SCP-8100 Speaker Replacement, Back Panel: paso 2, imagen 2 de 2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Sanyo SCP-8100 Speaker Replacement: paso 3, imagen 1 de 1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Sanyo SCP-8100 Speaker Replacement: paso 4, imagen 1 de 2 Sanyo SCP-8100 Speaker Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Sanyo SCP-8100 Speaker Replacement: paso 5, imagen 1 de 3 Sanyo SCP-8100 Speaker Replacement: paso 5, imagen 2 de 3 Sanyo SCP-8100 Speaker Replacement: paso 5, imagen 3 de 3
    • While removing the back panel, take out the rubber cover on each side.
  6. Sanyo SCP-8100 Speaker Replacement, Speaker: paso 6, imagen 1 de 2 Sanyo SCP-8100 Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Pull the connector at the top of the back panel out.
    • You may need to use some force when pulling.
    • It may still be connected to the phone instead of the back panel.
  7. Sanyo SCP-8100 Speaker Replacement: paso 7, imagen 1 de 2 Sanyo SCP-8100 Speaker Replacement: paso 7, imagen 2 de 2
    • Use the opening tool to lift the speaker out from the right side.
Conclusión
Una persona más ha completado esta guía.
Paul Truong
Miembro Desde 04/15/13
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-41, Amido Spring 2013 Miembro de Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 395
