Saltar al contenido principal
Sanyo SCP-8100 Keypad Replacement
Qué necesitas
  1. Sanyo SCP-8100 Keypad Replacement, Battery: paso 1, imagen 1 de 3 Sanyo SCP-8100 Keypad Replacement, Battery: paso 1, imagen 2 de 3 Sanyo SCP-8100 Keypad Replacement, Battery: paso 1, imagen 3 de 3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Sanyo SCP-8100 Keypad Replacement, Back Panel: paso 2, imagen 1 de 2 Sanyo SCP-8100 Keypad Replacement, Back Panel: paso 2, imagen 2 de 2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Sanyo SCP-8100 Keypad Replacement: paso 3, imagen 1 de 1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Sanyo SCP-8100 Keypad Replacement: paso 4, imagen 1 de 2 Sanyo SCP-8100 Keypad Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Sanyo SCP-8100 Keypad Replacement: paso 5, imagen 1 de 3 Sanyo SCP-8100 Keypad Replacement: paso 5, imagen 2 de 3 Sanyo SCP-8100 Keypad Replacement: paso 5, imagen 3 de 3
    • While removing the back panel, take out the rubber cover on each side.
  6. Sanyo SCP-8100 Keypad Replacement, Keypad: paso 6, imagen 1 de 2 Sanyo SCP-8100 Keypad Replacement, Keypad: paso 6, imagen 2 de 2
    • Pull the volume and camera buttons off from the side of the phone.
  7. Sanyo SCP-8100 Keypad Replacement: paso 7, imagen 1 de 2 Sanyo SCP-8100 Keypad Replacement: paso 7, imagen 2 de 2
    • Pull the gray frame covering the charging port from the bottom of the phone.
  8. Sanyo SCP-8100 Keypad Replacement: paso 8, imagen 1 de 2 Sanyo SCP-8100 Keypad Replacement: paso 8, imagen 2 de 2
    • Use the opening tool to lift the motherboard up from the phone.
    • Be careful and pry the motherboard off slowly. The motherboard will be attached to the phone at the top by a metal ribbon.
  9. Sanyo SCP-8100 Keypad Replacement: paso 9, imagen 1 de 3 Sanyo SCP-8100 Keypad Replacement: paso 9, imagen 2 de 3 Sanyo SCP-8100 Keypad Replacement: paso 9, imagen 3 de 3
    • Flip open the phone, exposing the keypad.
    • Use the opening tool to push the buttons from the bottom to lift the rubber keypad up.
    • Pull the keypad out of the phone.
Conclusión
Una persona más ha completado esta guía.
Irenz Afable
Miembro Desde 04/15/13
57 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-41, Amido Spring 2013 Miembro de Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 377
