Introducción
This guide will show you how to properly install a camera for the Sanyo SCP-8100. If your device is having trouble taking pictures or it will not take pictures at all, you may need to install a new camera.
You will need to open the front panel and remove the LCD board in order to get to the camera piece.
Qué necesitas
Open the phone and remove the four stickers that hide the four 0.5 mm screws.
On the bottom two, use a push pin to pull out the stickers.
