Saltar al contenido principal
Sanyo Katana Screen Replacement
Qué necesitas
  1. Sanyo Katana Screen Replacement, Screen Protector: paso 1, imagen 1 de 2 Sanyo Katana Screen Replacement, Screen Protector: paso 1, imagen 2 de 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Screen Replacement: paso 2, imagen 1 de 2 Sanyo Katana Screen Replacement: paso 2, imagen 2 de 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Screen Replacement: paso 3, imagen 1 de 2 Sanyo Katana Screen Replacement: paso 3, imagen 2 de 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Screen Replacement, Front Case: paso 4, imagen 1 de 3 Sanyo Katana Screen Replacement, Front Case: paso 4, imagen 2 de 3 Sanyo Katana Screen Replacement, Front Case: paso 4, imagen 3 de 3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
  5. Sanyo Katana Screen Replacement, Screen: paso 5, imagen 1 de 2 Sanyo Katana Screen Replacement, Screen: paso 5, imagen 2 de 2
    • Using a Tri-wing Y0 screwdriver, remove the 4.4mm screw.
    • Use fingers to remove the strip from the device.
  6. Sanyo Katana Screen Replacement: paso 6, imagen 1 de 3 Sanyo Katana Screen Replacement: paso 6, imagen 2 de 3 Sanyo Katana Screen Replacement: paso 6, imagen 3 de 3
    • Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen.
  7. Sanyo Katana Screen Replacement: paso 7, imagen 1 de 2 Sanyo Katana Screen Replacement: paso 7, imagen 2 de 2
    • Use the flat edge of the spudger to detach the screen from the phone casing.
    • Pull the screen up and away from the case.
Conclusión
Aliceann
Miembro Desde 03/11/13
49 Reputación
1 Guía escrita
Equipo
Clemson, Team 12-1, Benson Spring 2013 Miembro de Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 614
