Saltar al contenido principal
Sanyo Katana Screen Protector Replacement
Qué necesitas
  1. Sanyo Katana Screen Protector Replacement, Screen Protector: paso 1, imagen 1 de 2 Sanyo Katana Screen Protector Replacement, Screen Protector: paso 1, imagen 2 de 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Screen Protector Replacement: paso 2, imagen 1 de 2 Sanyo Katana Screen Protector Replacement: paso 2, imagen 2 de 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Screen Protector Replacement: paso 3, imagen 1 de 2 Sanyo Katana Screen Protector Replacement: paso 3, imagen 2 de 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
Conclusión
StephenYH
Miembro Desde 03/11/13
20 Reputación
3 Guías creadas
Equipo
Clemson, Team 12-1, Benson Spring 2013 Miembro de Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 318
