Saltar al contenido principal
Introducción
This guide will illustrate for you how to replace the battery from a Sanyo Katana Eclipse X.
Partes
No se especificaron partes.
  1. Sanyo Katana Eclipse X Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Sanyo Katana Eclipse X Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Sanyo Katana Eclipse X Battery Replacement: paso 2, imagen 1 de 1
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Sanyo Katana Eclipse X Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Align the copper receptors on the back of your battery so the phone's copper receptors are touching the battery terminals.
    • Refer to photo illustrations.
    • Using your thumb, apply gentle pressure to the battery until it clicks into place.
  4. Sanyo Katana Eclipse X Battery Replacement: paso 4, imagen 1 de 1
    • Take the phone’s back casing and set it over the battery.
    • Apply gentle pressure, pushing towards the top of the phone until your hear a click.
Conclusión
Thomas Scaggs
Miembro Desde 15/10/12
209 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 361
