Saltar al contenido principal
Sanyo Katana Camera Replacement
Qué necesitas
  1. Sanyo Katana Camera Replacement, Screen Protector: paso 1, imagen 1 de 2 Sanyo Katana Camera Replacement, Screen Protector: paso 1, imagen 2 de 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Camera Replacement: paso 2, imagen 1 de 2 Sanyo Katana Camera Replacement: paso 2, imagen 2 de 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Camera Replacement: paso 3, imagen 1 de 2 Sanyo Katana Camera Replacement: paso 3, imagen 2 de 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Camera Replacement, Front Case: paso 4, imagen 1 de 3 Sanyo Katana Camera Replacement, Front Case: paso 4, imagen 2 de 3 Sanyo Katana Camera Replacement, Front Case: paso 4, imagen 3 de 3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
  5. Sanyo Katana Camera Replacement, Camera: paso 5, imagen 1 de 3 Sanyo Katana Camera Replacement, Camera: paso 5, imagen 2 de 3 Sanyo Katana Camera Replacement, Camera: paso 5, imagen 3 de 3
    • Use a Tri-wing Y0 screwdriver to remove the 4.4mm screw.
    • Use fingers to remove the strip.
  6. Sanyo Katana Camera Replacement: paso 6, imagen 1 de 3 Sanyo Katana Camera Replacement: paso 6, imagen 2 de 3 Sanyo Katana Camera Replacement: paso 6, imagen 3 de 3
    • Detach the ribbon connections underneath the green connector strip and remove them from the device. This will reveal the camera.
  7. Sanyo Katana Camera Replacement: paso 7, imagen 1 de 3 Sanyo Katana Camera Replacement: paso 7, imagen 2 de 3 Sanyo Katana Camera Replacement: paso 7, imagen 3 de 3
    • Using a spudger, remove the ribbon connection of the camera from the adhesive that attaches it to the device.
    • Grab the camera using fingers and remove it from the phone case.
Conclusión
Preston
Miembro Desde 03/11/13
216 Reputación
5 Guías creadas
Equipo
Clemson, Team 12-1, Benson Spring 2013 Miembro de Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 321
