Saltar al contenido principal
Sansa e260R Front Panel Replacement
Qué necesitas
  1. Sansa e260R Front Panel Replacement, Rear Case: paso 1, imagen 1 de 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Front Panel Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Front Panel Replacement: paso 3, imagen 1 de 1
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Front Panel Replacement, Battery: paso 4, imagen 1 de 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Front Panel Replacement, Front Panel: paso 5, imagen 1 de 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Front Panel Replacement: paso 6, imagen 1 de 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Front Panel Replacement: paso 7, imagen 1 de 2 Sansa e260R Front Panel Replacement: paso 7, imagen 2 de 2
    • Pull the front cover away from the rest of the device.
Conclusión
Casey Smith
Miembro Desde 01/20/12
111 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 8-15, Maness Winter 2012 Miembro de Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 1,994
