Saltar al contenido principal
Sanitaire SC684 Roller Brusher and Drive Belt Replacement
  1. Sanitaire SC684 Roller Brusher and Drive Belt Replacement, Roller Brush and Belt: paso 1, imagen 1 de 1
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay the vacuum on its back.
  2. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 2, imagen 1 de 1
    • Find the metal plate (located directly in the center).
    • Locate the two latches on either side of the metal plate.
    • Detach the latches by pulling them away from metal plate.
  3. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 3, imagen 1 de 1
    • Remove the metal plate by pulling it towards you.
  4. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 4, imagen 1 de 1
    • Identify the belt and brush roller.
    • The belt is a black ring made of rubber.
    • The brush roller is the long metal tube with bristles attached to it.
  5. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 5, imagen 1 de 1
    • Remove the belt from the circular knob by inserting your fingers on either side, gently lifting towards you.
  6. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 6, imagen 1 de 2 Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 6, imagen 2 de 2
    • Pull brush roller out and slip the belt off from the indent in the middle of the roller.
Conclusión
Caycie Pascual
Miembro Desde 09/26/12
1 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 16-58, Forte Fall 2012 Miembro de Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 2,803
