Herramientas
No se requieren herramientas.
Partes
  1. Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
    Agregar Comentario
  2. Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
    Agregar Comentario
    • Lift off the metal plate by pulling it towards you.
    Agregar Comentario
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
    Agregar Comentario
    • Slide the belt off of the circular knob.
    Agregar Comentario
    • Pull brush roller out and detach the belt off the brush roller.
    Agregar Comentario
Conclusión
Caycie Pascual
Miembro Desde 26/09/12
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 16-58, Forte Fall 2012 Miembro de Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 826
